Enabling the Gateway globally
Use this procedure to enable the Gateway at the global (switch-wide) level.
 - Select SPBM.
 - In the row for the SPMB, double click the McastSpbPimGwGatewayEnable field, and then select true.
 - Select Apply.
SPBM field descriptions
Use the data in the following table to use the SPBM tab.
 Name  |
 Description  |
 McastSpbPimGwControllerEnable  |
 Enables or disables the ISIS multicast SPM-PIM Gateway Controller node.  |
 McastSpbPimGWGatewayEnable  |
 Enables or disables the ISIS multicast SPM-PIM Gateway node.  |
