Use the following procedure to configure an IKEv2 profile.
Variable Definition
The following table defines parameters for the ike v2–profile commands.
 Variable  |
 Value  |
 profile WORD<1–32>  |
 Specifies the IKE v2–profile name.  |
 hash-algo <md5|sha|sha256|any>  |
 Specifies the type of hash algorithm. The default value is sha256. To set this option to the default value, use the default operator with the command: default ike v2–profile WORD<1–32> hash-algo  |
 encrypt-algo <desCbc|3DesCbc|aesCbc|any>  |
 Specifies the type of encryption algorithm. The default value is aesCbc. To set this option to the default value, use the default operator with the command: default ike v2–profile WORD<1–32> encrypt-algo  |
 integrity-algomd5|sha-1|sha-256|aes-xcbc  |
 Specifies the type of integrity algorithm. The default is sha256. To set this option to the default value, use the default operator with the command: default ike v2–profile WORD<1–32> integrity-algo  |
 dh-group <modp768|modp1024|modp2048|any>  |
 Specifies the Diffie-Hellman (DH) group. DH groups categorize the key used in the key exchange process, by its strength. The key from a higher group number is more secure. The default value is modp2048. To set this option to the default value, use the default operator with the command: default ike v2–profile WORD<1–32> dh-group  |
 encrypt-key-len <128|192|256>  |
 Specifies the length of the encryption key. The default is 256. To set this option to the default value, use the default operator with the command: default ike v2–profile WORD<1–32> encrypt-key-len  |
 lifetime-sec <0-4294967295>  |
 Specifies the lifetime value in seconds. The lifetime ensures that the peers renegotiate the SAs just before the expiry of the lifetime value, to ensure that Security Associations are not compromised. The default value is 86400 seconds. To set this option to the default value, use the default operator with the command: default ike v2–profile WORD<1–32> lifetime-sec  |
