View information about TCP connections.
Among other things, the fields on the TCP connections tab provide important information about the health of connections that traverse your switch.
In particular, the state column lets you know the state of each TCP connection. Of these, synSent, synReceived, and established indicate whether or not a channel is established and listen indicates when an end system is waiting for a returning handshake (SYN).
- In the navigation pane, expand the : folders.
 - Click TCP/UDP.
 - Click the TCP Connections tab.
TCP Connections field descriptions
Use the data in the following table to use the TCP Connections tab.
Name  | Description  |
LocalAddressType  | Displays the type (IPv6 or IPv4) for the address in the LocalAddress field.  |
LocalAddress  | Displays the IPv6 address for the TCP connection.  |
LocalPort  | Displays the local port number for the TCP connection.  |
RemAddressType  | Displays the type (IPv6 or IPv4) for the remote address of the TCP connection.  |
RemAddress  | Displays the IPv6 address for the remote TCP connection.  |
RemPort  | Displays the remote port number for the TCP connection.  |
State  | Displays an integer that represents the state for the connection:
Process  | Displays the process ID for the system process associated with the TCP connection.  |
