Show SLPP information for a port so that you can view the loop information for a port.
Switch# show slpp interface GigabitEthernet 1/7
                                    Port Interface
   PORT        PKT-RX      PKT-RX     INCOMING   SLPP PDU
   NUM                     THRESHOLD  VLAN ID    ORIGINATOR
   1/7         enabled     5
   PORT        PKT-RX      TIME LEFT
   NUM         COUNT       TO CLEAR RX COUNT
   1/7         29          21600
Use the data in the following table to use the show slpp interface GigabitEthernet command.
                             Variable  |
                             Value  |
                             {slot/port[/sub-port][-slot/port[/sub-port]][,...]}  |
                             Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
