This procedure does not apply to VSP 8600 Series and XA1400 Series.
Use this procedure to configure the maximum NEAP clients allowed on the Auto-sense enabled port at one time.
If you manually configure values on a specific port(s), then these values will take precedence over the Auto-sense global values.
    enable
    configure terminal
  2. Configure the maximum NEAP clients allowed on Auto-sense enabled ports:
    auto-sense eapol multihost non-eap-mac-max <0-8192>
    Eapol multihost eap-mac-max also provides the EAP and NEAP separation functionality. By default, the system enables NEAP clients on each port with a maximum limit of 2 NEAP clients. If you configure the maximum limit to 0 then the system disables the NEAP client authentication.
Configure a maximum of 10 NEAP clients allowed on the Auto-sense enabled port at one time.
Switch:1>enable
Switch:1#configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
Switch:1(config)#auto-sense eapol multihost non-eap-mac-max 10
