Use the following procedure to display the next hop for the logical interface.
 - Select the Logical Interfaces NextHop tab.
Logical Interfaces NextHop field descriptions
Use the data in the following table to use the Logical Interfaces NextHop tab.
                         Name  |
                         Description  |
                         Id  |
                         Shows a unique value that identifies the logical interface tunnel.  |
                         Ip  |
                         Shows a unique value that identifies the next hop IP address of the logical interface tunnel.  |
                         DestIfIndex  |
                         Shows the next hop destination interface index to reach the next hop IP of the logical interface tunnel.  |
                         DestVid  |
                         Shows the next hop destination VLAN ID to reach the next hop IP of the logical interface tunnel.  |
