Configure link flap detection to control link state changes on a physical port.
 - Click General.
 - Click the Link Flap tab.
 - Configure the parameters as required.
 - Click Apply.
Link Flap Field Descriptions
Use the data in the following table to use the Link Flap tab.
 Name  |
 Description  |
 AutoPortDownEnable  |
 Enables or disables Link Flap Detect. If you enable Link Flap Detect, the system monitors the number of times a port goes down during a designated interval. If the number of drops exceeds a specified limit, the system forces the port out-of-service. The default is enabled.  |
 SendTrap  |
 Specifies that a trap is sent if the port is forced out-of-service.  |
 Frequency  |
 Specifies the number of times the port can go down. The default is 20.  |
 Interval  |
 Specifies the interval (in seconds) between port failures. The default is 60.  |
