Create a rag_pol_1
                                                RA Guard policy for the router and configure the source
                                                IPv6 access list to allow only the RA packets that
                                                originate from the source IPv6 address fe80:0:0:0:cef9:54ff:feb4:9481/128. This
                                                configuration verifies the prefixes sent in the RA
                                                packets.
        Enter Global Configuration mode:
          enable
          configure
              terminal
                                                Enter the RA Guard mode and configure RA Guard policy (rag_pol_1) for the interface connected
                                                  to a router.
                                                  ipv6 fhs ra-guard policy
                                                  rag_pol_1
                                     - Configure the source
IPv6 access list to allow only RA packets originating from the source
match ipv6 ra-srcaddr-list ipv6_acl_1
 - Verify the prefixes sent in the RA packets so that the
rtr_pip IPv6 ACL configuration allows only the prefix 60::0/64.
match reply ra-prefix-list ipv6_acl_1
