This procedure only applies to the VSP 7400 Series.
Perform this procedure to view the remote link-state packet (LSP) summary information. Link State Packets (LSP) contain information about the state of adjacencies or defined and distributed static routes. Intermediate-System-to-Intermediate-System (IS-IS) exchanges this information with neighboring IS-IS routers at periodic intervals.
  1. In the navigation pane, expand the Configuration > Fabric folders.
  2. Select IS-IS Remote.
  3. Select the LSP Summary tab.
LSP Summary Field Descriptions
Use the data in the following table to use the LSP Summary tab.
Name
Description
Level
Specifies the level at which the system displays the remote LSP.
ID
Specifies the 8-byte LSP ID, consisting of the system ID, circuit ID, and Fragment Number.
Seq
Specifies the sequence number for the LSP.
Checksum
Specifies the 16-bit Fletcher Checksum for the LSP.
LifetimeRemain
Specifies the remaining lifetime in seconds for the LSP.
HostName
Specifies the host name.
