You must first enable BootP/DHCP relay on a port (or VLAN).
You must enable DHCP and forwarding path.
You must enable IP Routing on the interface.
Use the DHCP tab to configure the DHCP behavior on a brouter port or a VRF instance. The DHCP tab is available only if the port is routed (that is, assigned an IP address).
- In the Device Physical View tab, select a port.
 - Click IP.
 - Click the DHCP Relay tab.
 - Click Enable to select the DHCP option. The default is disable.
 - Configure the other parameters as needed.
 - Click Apply.
DHCP field descriptions
Use data from the following table in the DHCP Relay tab.
 Name  |
 Description  |
 Enable  |
 Lets you use BootP/DHCP on the port. The default is disable.  |
 MaxHop  |
 Sets the maximum number of hops before a BootP/DHCP packet is discarded (1 to 16). The default is 4.  |
 MinSec  |
 The secs field in the BootP/DHCP packet header represents the elapsed time since the client first sent the message. If the secs field in the packet header is greater than this value, the system relays or forwards the packet; otherwise, the packet is dropped. The default is 0 seconds.  |
 Mode  |
 Sets the interface to process only BootP, only DHCP, or both types of packets. The default is both.  |
 AlwaysBroadcast  |
 When enabled, the server reply is sent as a broadcast back to the end station. The default is disable.  |
 CircuitId  |
 Indicates whether DHCP Relay inserted the option 82 circuit ID information into the DHCP packets before sending the DHCP packets to the DHCP server. The default is disable.  |
 RemoteId  |
 Indicates whether DHCP Relay inserted the option 82 remote ID information into the DHCP packets before sending the DHCP packets to the DHCP server. The default is disable.  |
 Trusted  |
 Indicates if DHCP packets come through a trusted DHCP circuit. Only packets with GIADDR configured to 0 and containing option 82 are forwarded if the circuit is trusted. The default value is false.  |
