Perform this procedure to view the maximum MAC learning limit information for an I-SID.
Important
The command show i-sid limit-fdb-learning is supported only on the VSP 4450 Series.
The total MAC learning limit per switch is 32000. MAC learning on I-SID stops when the maximum limit is reached.
show i-sid limit-fdb-learning <1-16777215>
View maximum MAC learning limit for all I-SIDs.
Switch:1#show i-sid limit-fdb-learning
        Isid MAC-Limit Info
ISID        MAC-LIMIT   MAXMAC
ID          STATUS      COUNT
10          disabled    32000
11          disabled    32000
12          disabled    32000
15          disabled    32000
101         disabled    32000
All 5 out of 5 Total Num of i-sid Info displayed
                        View maximum MAC learning limit for a specific I-SID.
Switch:1#show i-sid limit-fdb-learning 10
        Isid MAC-Limit Info
ID          STATUS      COUNT
10          disabled    32000
All 1 out of 1 Total Num of i-sid Info displayed
                Variable definitions
The following table defines parameters for the show i-sid limit-fdb-learning command.
Important
                                                   Variable  |
                                                   Value  |
                                                   limit-fdb-learning  |
                                                   Displays the I-SID-based maximum MAC limit information.  |
                                                   <1–6777215>  |
                                                   Displays the service interface identifier (I-SID). The I-SID range is 1 to 16777215.  |
