This procedure only applies to the VSP 7400 Series.
Perform this procedure to configure the remote Intermediate System-to-Intermediate System (IS-IS) system ID on the switch.
Configuring the remote IS-IS system ID:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#router isis remote Switch:1(config-isis-remote)#system-id 0017.c6ed.44df
What to do next
To verify the configuration, see Display IS-IS Remote Area Configuration and Display IS-IS Area Configuration.
The following table defines parameters for the system-id command.
| Variable | Value |
| xxxx.xxxx.xxxx |
                                 Specifies the remote IS-IS system ID for the switch.  |
