Configure a redistribute entry to announce routes of a certain source protocol into the OSPFv3 domain. Optionally, use a route policy to control the redistribution of routes.
Important
Changing the OSPFv3 redistribute context is a process-oriented operation that can affect system performance and network reachability while you perform this procedure. As a best practice, change the default preferences for an OSPFv3 redistribute context, you must do so before you enable the protocols.
Enable OSPFv3 globally.
Ensure that a route policy exists if you intend to use a route policy.
Change the VRF instance as required to configure OSPFv3 on a specific VRF instance. The VRF must have an RP trigger of OSPFv3. Not all parameters are configurable on non-default VRFs.
 - Click OSPFv3.
 - Click the Redistribute tab.
 - Click Insert.
 - Select an option for the route source.
 - Select the enable option button.
 - Select a route policy.
 - Configure the metric type.
 - Click Insert.
Redistribute Field Descriptions
Use the date in the following table to use the Redistribute tab.
 Name  |
 Description  |
 DstVrfId  |
 Specifies the destination virtual router forwarding instance. You cannot configure this variable.  |
 Protocol  |
 Specifies the dynamic routing protocol that receives the external routing information.  |
 SrcVrfId  |
 Specifies the source VRF instance. You cannot configure this variable.  |
 RouteSource  |
 Specifies the route source protocol for the redistribution entry.  |
                         Enable  |
                         Enables (or disables) an OSPF redistribute entry for a specified source type.  |
                         RoutePolicy  |
                         Configures the route policy (by name) to use for detailed redistribution of external routes from a specified source into an OSPF domain. Click the ellipsis (...) button and choose from the list in the dialog box.  |
                         Metric  |
                         Configures the OSPF route redistribution metric for basic redistribution. The value can be a range from 0–65535. A value of 0 indicates to use the original cost of the route.  |
                         MetricType  |
                         Configures the OSPF route redistribution metric type. The default is type 2. The cost of a type 2 route is the external cost, regardless of the interior cost. A type 1 cost is the sum of both the internal and external costs.  |
