This procedure does not apply to VSP 8600 Series.
Use this task to view IPv6 ICMP statistics for a Segmented Management Instance.
 - Select Mgmt Instance.
 - Select Stats.
 - Select the IPv6-ICMP tab.
 - To clear IP statistics, select Clear Stats.
 - To clear IP counters, select Clear Counters.
IPv6-ICMP Field Descriptions
Use the data in the following table to use the IPv6-ICMP tab.
                 Name  |
                 Description  |
                 InMsgs  |
                 Shows the inbound messages statistics.  |
                 InErrors  |
                 Shows the inbound errors statistics.  |
                 InCsumErrors  |
                 Shows the inbound checksum errors statistics.  |
                 InDestUnreachs  |
                 Shows the inbound destination unreachable statistics.  |
                 InTimeExcds  |
                 Shows the inbound time exceeded statistics.  |
| InParmProbs |
                 Shows the inbound parameter problems statistics.  |
| InPktTooBigs |
                 Shows the inbound packets too big statistics.  |
| InRedirects |
                 Shows the inbound redirects statistics.  |
| InEchos |
                 Shows the inbound echos statistics.  |
| InEchoReplies |
                 Shows the inbound echo replies statistics.  |
| InGroupMembQueries |
                 Shows the inbound group member queries statistics.  |
| InGroupMembResponses |
                 Shows the inbound group member responses statistics.  |
| InGroupMembReductions |
                 Shows the inbound group member reductions statistics.  |
| InRouterSolicits |
                 Shows the inbound router solicits statistics.  |
| InRouterAdvertisements |
                 Shows the inbound router advertisements statistics.  |
| InNeighborSolicits | Shows the inbound neighbor solicits statistics. |
| InNeighborAdvertisements | SHows the inbound neighbor advertisements statistics. |
| InMLDv2Reports | Shows the inbound MLDv2 reports statistics. |
| InType134 | Shows the inbound type134 statistics. |
| InType136 | Shows the inbound type136 statistics. |
| OutMsgs |
                 Shows the outbound messages statistics.  |
| OutErrors |
                 Shows the outbound errors statistics.  |
| OutDestUnreachs |
                 Shows the outbound destination unreachable statistics.  |
| OutTimeExcds |
                 Shows the outbound time exceeded statistics.  |
| OutParmProbs |
                 Shows the outbound parameter problems statistics.  |
| OutPktTooBigs |
                 Shows the outbound packets too big statistics.  |
| OutRedirects |
                 Shows the outbound redirects statistics.  |
| OutEchos |
                 Shows the outbound echos statistics.  |
| OutEchoReps |
                 Shows the outbound echo replies statistics.  |
| OutGroupMembQueries |
                 Shows the outbound group member queries statistics.  |
| OutGroupMembResponses |
                 Shows the outbound group member responses statistics.  |
| OutGroupMembReductions |
                 Shows the outbound group member reductions statistics.  |
| OutRouterStatistics |
                 Shows the outbound router statistics  |
| OutRouterAdvertisements |
                 Shows the outbound router advertisements statistics.  |
| OutNeighborSolicits |
                 Shows the outbound neighbor solicits statistics.  |
| OutNeighborAdvertisements |
                 Shows the outbound neighbor advertisements statistics.  |
| OutMLDv2Reports |
                 Shows the outbound MLDv2 reports statistics.  |
| OutType133 |
                 Shows the outbound Type133 statistics.  |
| OutType135 |
                 Shows the outbound Type135 statistics.  |
| OutType143 |
                 Shows the outbound Type143 statistics.  |
