This procedure only applies to the VSP 7400 Series.
Perform this procedure to view the remote Intermediate-System-to-Intermediate-System (IS-IS) interface control packets.
  1. In the navigation pane, expand the Configuration > Fabric folders.
  2. Select Stats Remote.
  3. Select the Interface Control Packets tab.
Interface Control Packets Field Descriptions
Use the data in the following table to use the Interface Control Packets tab.
Name
Description
Index
Shows a unique value identifying the Intermediate-System-to-Intermediate-System (IS-IS) interface.
Level
Specifies the level.
Direction
Indicates whether the switch is sending or receiving the PDUs.
Hello
Indicates the number of IS-IS Hello frames seen in this direction at this level.
LSP
Indicates the number of IS-IS LSP frames seen in this direction at this level.
CSNP
Indicates the number of IS-IS Complete Sequence Number Packets (CSNP) frames seen in this direction at this level.
PSNP
Indicates the number of IS-IS Partial Sequence Number Packets (PSNP) frames seen in this direction at this level.
