This procedure does not apply to VSP 8600 Series.About this task
Use this task to view Fragmented ICMP packet filtering details on a Management Instance.
- To enter User EXEC mode, log on to the switch.
                View Fragmented ICMP packet
                    filtering:
For IPv4:
show mgmt ip icmp [clip | oob | vlan]
For IPv6:
show mgmt ipv6 icmp [clip | oob | vlan]
This command does not apply to XA1400 Series.
The following table defines parameters for the show mgmt ip icmp command.
                             Variable  |
                             Value  |
                             clip  |
                             Displays the IPv4 or IPv6 ICMP information specific to the management CLIP.  |
                             oob  |
                             Displays the IPv4 or IPv6 ICMP information specific to the management OOB.  |
                             vlan  |
                             Displays the IPv4 or IPv6 ICMP information specific to the management VLAN.  |
