Displays the OSPF redistribution configuration information.
The route policies treat permit and deny rules differently for inbound and outbound traffic.
For an in-policy (RIP, BGP) or an accept policy (OSPF) using a route-map, if a particular route is not explicitly denied in the accept policy or in-policy with the route-map, then the route is implicitly allowed.
For an out-policy (RIP, BGP) or a redistribute policy (RIP, OSPF, BGP) using a route-map, even if a particular route is not explicitly allowed in the redistribution policy or out-policy with the route-map, then the route is implicitly denied.
In order to permit or deny only explicit routes, configure a policy with additional sequences, where, the last sequence permits all routes that are not explicitly permitted or denied.
Switch:1#show ip ospf redistribute
                     OSPF Redistribute List - GlobalRouter
SRC-VRF          SRC  MET MTYPE SUBNET   ENABLE RPOLICY
GlobalRouter     STAT 0   type2 allow    TRUE
   Variable definitions
The following table defines parameters for the show ip ospf redistribute command.
 Variable  |
 Value  |
 vrf WORD<1-16>  |
 Specifies a VRF by name.  |
 vrfids WORD<0-512>  |
 Specifies a range of VRF IDs.  |
