Perform this procedure to create an IPv6 CLIP interface and associate it with a specific VRF.
  1. Enter Loopback Interface Configuration mode
    enable
    configure terminal
    interface Loopback <1-256>
  2. Create an IPv6 loopback interface address:
    ipv6 interface address WORD <0-255> vrf WORD <1–16>
  3. Optional: Enter a name for the IPv6 address:
    ipv6 interface name WORD <0-64>
  4. Ensure the configuration is correct:
    show ipv6 interface loopback <1–256>
Switch:1#show ipv6 interface loopback
                                                Loopback Ipv6 Interfaces
IF   VRF          Descr    VLAN PHYSICAL       ADMIN   OPER  TYPE  MTU HOP REACHABLE  RETRANSMIT  IPSEC
INDX NAME                       ADDRESS        STATE   STATE           LMT TIME       TIME        STATE
1348 GlobalRouter CLIPv6-5 --00:00:00:00:00:05 enable  up    ETHER 1500 64 30000     1000     disable
                                        Loopback IPv6 Addresses
IPV6 ADDRESS/PREFIX LENGTH      LOOPBACK-ID  TYPE    ORIGIN    STATUS               NAME
2001:db8:0:0:0:0:0:ffff/32       C-5        UNICAST  MANUAL    PREFERRED INF  INF  EXTREMESERVER_2
Legend: NA - Information not available
1 out of 1 Total Num of Interface Entries displayed.
1 out of 1 Total Num of Address Entries displayed.
Use the data in the following table to use the ipv6 commands.
Variable
Value
ospf <1-256> enable
Note:
Exception: Only supported on VSP 8600 Series.
Enables OSPFv3 instance on the CLIP interface.
WORD<1–256>
Specifies the CLIP interface ID.
WORD<0–255>
Specifies the IPv6 address.
vrf WORD<1–16>
Specifies the VRF name.
WORD<0–64>
Specifies the I-SID name associated with the IPv6 address.
