The virtual services running on a Virtual Machine (VM) require a console for configuration and monitoring purposes.
Perform this procedure to access the virtual service console port for the specific VM.
Switch:1>enable Switch:1#virtual-service tpvm console
The following table defines parameters for the virtual-service command.
                                 Variable  |
                                 Value  |
                                 WORD<1-128>  |
                                 Specifies the virtual service name.  |
                                 console  |
                                 Accesses the console for the specific virtual service.  |
