Use the following procedure to display multiple host status for a port.
 - Select 802.1X – EAPOL.
 - Select the MultiHost Status tab.
MultiHost Status Field Descriptions
The following table describes values on the MultiHost Status tab.
 Name  |
 Description  |
 PortNumber  |
 Indicates the port number associated with this port.  |
 ClientMACAddr  |
 Indicates the MAC address of the client.  |
 PaeState  |
 Indicates the current state of the authenticator PAE state machine.  |
 VlanId  |
 Indicates the VLAN assigned to the client.  |
 Priority  |
 Specifies the priority associated with this client MAC. This priority could be the Radius assigned priority or the port QOS level.  |
                                 SwUniBindings Note: Exception: Not supported on
                                        VSP 4450
					Series, VSP 8600
					Series, or XA1400
					Series.
                                 Indicates the Extensible Authentication Protocol (EAP) VLAN:ISID bindings that the switch represents as an hexadecimal value.  |
                                 IsidSource Note: Exception: Not supported on
                                        VSP 4450
					Series, VSP 8600
					Series, or XA1400
					Series.
                                 Indicates the origin of I-SID value:
                                 AclId Note: Exception: Not supported on
                                        VSP 4450
					Series, VSP 8600
					Series, or XA1400
					Series.
                                 Indicates the dynamic Access Control List (ACL) on the specific port.  |
                                 AceIdList
                                        on VSP 4450
					Series, VSP 8600
					Series, or XA1400
					Series.
                                 Indicates the list of dynamic Access Control Entries (ACE) on the specific port.  |
                                 DynamicSettings  |
                                 Displays the Dynamic settings received from the Remote Authentication Dial-In User Service (RADIUS) server.  |
