This procedure only applies to the VSP 7400 Series.
Perform this procedure to configure the Multi-area SPB layer 2 multicast redistribution for specific I-SID value(s) in the remote area.
 - Select MultiArea.
 - Select the L2 MC Redist Remote ISID tab.
 - Select Insert.
 - In the I-sid field, type the I-SID value.
 - Select Enable.
 - Optional: In the PolicyName field, type the name of the redistribution policy.
 - Select Insert.
L2 MC Redist Remote ISID Field Descriptions
Use the data in the following table to use the L2 MC Redist Remote ISID tab.
| Name | Description |
                                 I-sid  |
                                 Specifies the I-SID value.  |
                                 Enable  |
                                 Enables layer 2 multicast redistribution for specific I-SID value in the remote area.  |
                                 PolicyName  |
                                 Specifies the name of the redistribution policy.  |
