Assign an NTP key to use MD5 or SHA1 authentication on the server.
This procedure is only supported on VSP 8600 Series.
 - Select NTPv3.
 - Select the Key tab.
 - Select Insert.
 - Specify the secret key.
 - Select Insert.
Key field descriptions
Use the data in the following table to use the Key tab.
 Name  |
 Description  |
 KeyId  |
 Specifies the key ID that generates the MD5 or SHA1 digest.  |
 KeySecret  |
 Specifies the MD5 or SHA1 key that generates the MD5 or SHA1 digest. You must specify an alphanumeric string.  |
 KeyType  |
 Specifies the type of authentication, whether MD5 or SHA1. The default is MD5 authentication.  |
