Configuring VRRPv3 Checksum
Perform this procedure to configure VRRPv3 checksum on either a brouter port or a VLAN.
- In the navigation pane, expand the following folders: .
 - Click VRRP.
 - Click the V3 Checksum tab.
 - Click Insert.
 - In the Interface field, click Port or Vlan.
 - Select a type of checksum computation.
 - Select a VRRP version.
 - Click Insert.
V3 Checksum field descriptions
Use the data in the following table to use the V3 Checksum tab.
 Name  |
 Description  |
 Interface  |
 Shows VRRPv3 information about a specified interface.  |
 rcIpConfIfIndex  |
 Shows the index value that uniquely identifies the interface to which this entry applies.  |
 ChkSumComputation  |
 Specifies the type of checksum computation, with Pseudo Header or without Pseudo Header.  |
 VrrpVersion  |
 Specifies the VRRP version as unspecified, v2, or v3.  |
