View multiple spanning tree instance (MSTI) port statistics to manage network performance.
 - Click MSTP.
 - Click the MSTI Port tab.
 - Select a port, and then click Graph.
MSTI Field Descriptions
The following table describes parameters on the MSTI tab.
 Name  |
 Description  |
 ForwardTransitions  |
 Specifies the number of times this port has transitioned to the forwarding state for this specific instance.  |
 ReceivedBPDUs  |
 Specifies the number of BPDUs received by this port for this spanning tree instance.  |
 TransmittedBPDUs  |
 Specifies the number of BPDUs transmitted on this port for this spanning tree instance.  |
 InvalidBPDUsRcvd  |
 Specifies the number of invalid BPDUs received on this port for this spanning tree instance.  |
