Configure Port Rate Limits
This procedure does not apply to XA1400 Series.
Configure broadcast, unknown unicast, and multicast bandwidth limiting to limit the amount of ingress traffic on a port. The switch drops traffic that violates the bandwidth limit.
VSP 8600 Series does not support this feature for unknown unicast traffic.
- On the Device Physical View, select a port or multiple ports.
 - Select General.
 - Select the Rate Limiting tab.
 - In the row for the required traffic type, configure the bandwidth limit in AllowedRatePps.
 - In the row for the required traffic type, select true for Enable.
 - Select Apply.
Rate Limiting Field Descriptions
Use the data in the following table to use the Rate Limiting tab.
 Name  |
 Description  |
 Index  |
 Displays the port number.  |
 TrafficType  |
                                 Displays the type of traffic being rate limited, either broadcast/unknown unicast or multicast traffic. The default is broadcast, which means both broadcast and unknown unicast traffic.  |
 AllowedRatePps  |
 Specifies the allowed traffic rate limit for the port in packets per second (pps). 1–65535 configures the limit in packets for each second. The default is 25.  |
 Enable  |
 Enables or disables rate limiting. The default is false or disabled.  |
