This procedure does not apply to VSP 8600 Series.
Use the following procedure to view key health information about the types of control packets and protocols received on a port and sent to the segmented management instance interace.
- Expand Mgmt Instance.
- Select Stats
- Select the KHI tab.
- To clear KHI statistics for a management interface, select an InstanceId and select Clear Stats.
KHI Field Descriptions
Use the data in the following table to use the KHI tab.
| Name | Description |
| InstanceId | Shows the management interface instance. |
| PacketType | Shows the packet type. |
| PacketName | Shows the name of the packet. |
| RxPackets | Shows the number of received packets on the port for the packet type. |
| TxPackets | Shows the number of transmitted packets on the port for the packet type. |
| RxDropped | Shows the number of received packets dropped on the port for the packet type. |
