View port routing statistics to manage network performance.
This command is not available on all hardware platforms.
show routing statistics interface [gigabitethernet] [{slot/port[-slot/port][,...]}]
Switch:1#show routing statistics interface gigabitethernet 1/7-1/9
                               Port Stats Routing
PORT     IN_FRAME   IN_FRAME   IN         OUT_FRAME  OUT_FRAME
NUM      UNICAST    MULTICAST  DISCARD    UNICAST    MULTICAST
1/7      1386       0          0          1344       0
1/8      1302       0          0          1344       0
1/9      0          0          0          0          0
Use the data in the following table to use the show routing statistics interface command.
 Variable  |
 Value  |
 gigabitethernet  |
 Specifies the interface type.  |
 {slot/port[/sub-port][-slot/port[/sub-port]][,...]}  |
 Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
