Configure host routes when the switch resides in a network that uses routing protocols other than OSPF. A host route is a more-specific route and is used even if it is higher cost than a network route.
Globally enable OSPF.
You configure an OSPF host route on a VRF instance the same way you configure the GlobalRouter, except that you must use VRF Router Configuration mode and the prefix ip ospf. The VRF must have an RP Trigger of OSPF. Not all parameters are configurable on non0 VRFs.
Use a host route to create a custom route to a specific host to control network traffic.
You can specify which hosts directly attach to the router, and the metrics and types of service to advertise for the hosts.
Create a host route on IP address 192.0.2.20 with a metric of 20.
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#router ospf
Switch:1(config-ospf)#host-route 192.0.2.20 metric 20
Switch:1(config-ospf)#show ip ospf host-route
                         OSPF Host Route - GlobalRouter
HOSTIPADDR      TOS  METRIC
192.0.2.20      -    20
Variable definitions
The following table defines parameters for the host-route command.
 Variable  |
 Value  |
 {A.B.C.D}  |
 Specifies the IP address of the host router in a.b.c.d format.  |
 metric <0-65535>  |
 Configures the metric (cost) for the host route.  |
The following table defines parameters for the show ip ospf host-route command.
 Variable  |
 Value  |
 vrf WORD<1-16>  |
 Specifies a VRF by name.  |
 vrfids WORD<0-512>  |
 Specifies a range of VRF IDs.  |
