This procedure does not apply to VSP 8600 Series.
Use this task to view IP ICMP statistics for a Segmented Management Instance.
 - Select Mgmt Instance.
 - Select Stats.
 - Select the IP-ICMP tab.
 - To clear IP statistics, select Clear Stats.
 - To clear IP counters, select Clear Counters.
IP-ICMP Field Descriptions
Use the data in the following table to use the IP-ICMP tab.
                 Name  |
                 Description  |
                 InMsgs  |
                 Shows the inbound messages statistics.  |
                 InErrors  |
                 Shows the inbound errors statistics.  |
                 InCsumErrors  |
                 Shows the inbound checksum errors statistics.  |
                 InDestUnreachs  |
                 Shows the inbound destination unreachable statistics.  |
                 InTimeExcds  |
                 Shows the inbound time exceeded statistics.  |
| InParmProbs |
                 Shows the inbound parameter problems statistics.  |
| InSrcQuenchs |
                 Shows the inbound source quenchs statistics.  |
| InRedirects |
                 Shows the inbound redirects statistics.  |
| InEchos |
                 Shows the inbound echos statistics.  |
| InEchoReps |
                 Shows the inbound echo replies statistics.  |
| InTimestamps |
                 Shows the inbound timestamps statistics.  |
| InTimestampsReps |
                 Shows the inbound timestamp replies statistics.  |
| InAddrMasks |
                 Shows the inbound address masks statistics.  |
| InAddrMaskReps |
                 Shows the inbound address mask replies statistics.  |
| OutMsgs |
                 Shows the outbound messages statistics.  |
| OutErrors |
                 Shows the outbound errors statistics.  |
| OutDestUnreachs |
                 Shows the outbound destination unreachable statistics.  |
| OutTimeExcds |
                 Shows the outbound time exceeded statistics.  |
| OutParmProbs |
                 Shows the outbound parameter problems statistics.  |
| OutSrcQuenchs |
                 Shows the outbound source quenchs statistics.  |
| OutRedirects |
                 Shows the outbound redirects statistics.  |
| OutEchos |
                 Shows the outbound echos statistics.  |
| OutEchoReps |
                 Shows the outbound echo replies statistics.  |
| OutTimestamps |
                 Shows the outbound timestamps statistics.  |
| OutTimestampReps |
                 Shows the outbound timestamps replies statistics.  |
| OutAddrMasks |
                 Shows the outbound address masks statistics.  |
| MsgInType0 |
                 Shows the inbound Type0 messages statistics.  |
| MsgOutType8 |
                 Shows the outbound Type8 messages statistics.  |
