This procedure only applies to the VSP 7400 Series.
Perform this procedure to configure the Multi-area SPB Distributed Virtual Routing (DvR) backbone redistribtuion on the switch.
 - Select MultiArea
 - Select the DVR Redistribute tab.
 - Select DvrBbRedistribute.
 - Select Apply.
DVR Redistribute Field Descriptions
Use data in the following table to use the DVR Redistribute tab.
| Name | Description |
                                 DvrBbRedistribute  |
                                 Configures the Multi-area SPB DvR redistribution on the switch. The default is disabled.  |
