Use this procedure to display information about the MLD source.
- In the navigation pane, expand the following folders: .
 - Click IPv6 MLD.
 - Click the Source tab.
Source field description
Use the data in the following table to use the Source tab.
 Field  |
 Description  |
 GroupAddress  |
 Specifies the IPv6 multicast group address for which this entry contains information.  |
 Ifindex  |
 Specifies the interface for which this entry contains information for an IP multicast group address.  |
 InPort  |
 Identifies a physical interface or logical interface (VLAN), which has received group reports for this source.  |
 HostAddress  |
 Specifies the host address to which this entry corresponds.  |
 MemberAddress  |
 Specifies the IPv6 address of a member that has sent source specific report wishing to join this source.  |
 Expire  |
 Specifies the state of this entry.  |
 Mode  |
 Specifies the current member state. This is applicable to MLDv2 compatible nodes.  |
 MemberExpire  |
 Specifies the time until the member for this source expires.  |
