View OSPF statistics.
 - Select OSPF.
 - Select the Stats tab.
Graph OSPF Statistics
Graph OSPF statistics. The graph formats available are: line chart, area chart, bar chart, and pie chart.
Stats Field Descriptions
Use the data in the following table to use the OSPF Stats tab.
 Name  |
 Description  |
 AbsoluteValue  |
 Displays the counter value.  |
 Cumulative  |
 Displays the total value since you opened the Stats tab.  |
 Average/sec  |
 Displays the average value for each second.  |
 Minimum/sec  |
 Displays the minimum value for each second.  |
 Maximum/sec  |
 Displays the maximum value for each second.  |
 LastVal/sec  |
 Displays the last value for each second.  |
 LsdbTblSize  |
 Displays the number of entries in the link state database table.  |
 TxPackets  |
 Displays the number of packets transmitted by OSPF.  |
 RxPackets  |
 Displays the number of packets received by OSPF.  |
 TxDropPackets  |
 Displays the number of packets dropped before transmitted by OSPF.  |
 RxDropPackets  |
 Displays the number of packets dropped before received by OSPF.  |
 RxBadPackets  |
 Displays the number of packets received by OSPF that are bad.  |
 SpfRuns  |
 Displays the total number of SPF calculations performed by OSPF, which includes the number of partial route table calculation for incremental updates.  |
 BuffersAllocated  |
 Displays the number of buffers allocated for OSPF.  |
 BuffersFreed  |
 Displays the number of buffers that are freed by the OSPF.  |
 BufferAllocFailures  |
 Displays the number of times that OSPF has failed to allocate buffers.  |
 BufferFreeFailures  |
 Displays the number of times that OSPF has failed to free buffers.  |
 Routes  |
 Displays the number of OSPF routes added to RTM.  |
 Adjacencies  |
 Displays how many adjacencies are learned through the interface.  |
 Areas  |
 Displays the number of areas configured.  |
 Nbrs  |
 Indicates the number of OSPF neighbors.  |
 BadLsReqs  |
 Indicates the number of bad link state requests.  |
 SeqMismatches  |
 Indicates the number of sequence mismatched packets.  |
 NumAllocDDP  |
 Indicates the number of database description (DD) packet buffers allocated for OSPF.  |
 NumFreeDDP  |
 Indicates the number of DD packet buffers that are freed by the OSPF.  |
