This procedure only applies to the VSP 7400 Series.
Perform this procedure to view statistical graph of the remote IS-IS interface counters.
  1. In the navigation pane, expand the Configuration > Fabric folders.
  2. Select IS-IS Remote.
  3. Select the Interfaces tab.
  4. Select an interface.
  5. Select the Graph button.
Interface Counters Field Descriptions
The following table describes the fields in the Interface Counters tab.
Name
Description
InitFails
Indicates the number of times initialization of this circuit has failed. This counts events such as PPP NCP failures.
RejAdjs
Indicates the number of times an adjacency has been rejected on this circuit.
IDFieldLenMismatches
Indicates the number of times an Intermediate-System-to-Intermediate-System (IS-IS) control PDU with an ID field length different from that for this system has been received.
MaxAreaAddrMismatches
Indicates the number of times an IS-IS control PDU with a max area address field different from that for this system has been received.
AuthFails
Indicates the number of times an IS-IS control PDU with the correct auth type has failed to pass authentication validation.
LANDesISChanges
Indicates the number of times the Designated IS has changed on this circuit at this level. If the circuit is point to point, this count is zero.
AbsoluteValue
Displays the counter value.
Cumulative
Displays the total value since you opened the Stats tab.
Average/Sec
Displays the average value for each second.
Minimum/Sec
Displays the minimum value for each second.
Maximum/Sec
Displays the maximum value for each second.
Last Val/Sec
Displays the last value for each second.
