Use this procedure to control whether or not to supply power to specific slots that contain either switch fabric modules or input/output modules. By default, power is available to all slots.
After enabling power to specific input/output module slots, you can also configure the priority in which they are powered on. For more information, see Configuring Slot Priority.
Switch:1>enable
Switch:1#configure terminal
Enable power to Slot 1:
Switch:1 (config)# sys power slot 1
Disable power to Slot 1:
Switch:1 (config)# no sys power slot 1
Enable power to Slots 3 and 5:
Switch:1(config)#sys power slot 3,5
Disable power to Slots 3 and 5:
Switch:1(config)#no sys power slot 3,5
The following table defines parameters for the sys power slot command.
 Variable  |
 Value  |
 <1–4 | 1–8 | SF1–SF3>  |
 Identifies the slot to provide power in one of the following formats: a single slot (1), a range of slots (1–3), or a series of slots (1,2,4). The default is to provide power to all slots. Use the no operator to disable power to a slot. Use the default operator to enable power to a slot. Different hardware platforms support different slot ranges. Use the CLI Help to see the available range.  |
