Add ports to an MLT to insert MultiLink/LACP trunks.
In the navigation tree, expand the following folders: .
Click MLT/LACP.
Click the MultiLink/LACP Trunks tab.
In the PortMembers column, double-click the field associated with the MLT to which you want to add ports to.
Select the port numbers to add, or click All to add all ports to the MLT.
Up to 16 same-type ports can belong to a single MLT.
Click Ok.
Click Apply.
