This procedure only applies to the VSP 7400 Series.
Perform this procedure to configure Multi-area SPB layer 2 redistribution.
  1. In the navigation pane, expand the Configuration > Fabric folders.
  2. Select MultiArea.
  3. Select the L2 ISID Redist tab.
  4. Select Insert.
  5. Configure the layer 2 I-SID redistribution parameters.
  6. Select Insert.
L2 Redistribute Field Descriptions
Use the data in the following table to use the L2 Redistribute tab.
Name Description
Type
Specifies the layer 2 Redistribution type.
Permit
Configures the Multi-area SPB layer 2 I-SID redistribution policy as permit or deny.
ExceptListName
Configures the name of layer 2 I-SID list. The system does not apply the Multi-area SPB layer 2 I-SID redistribution policy to I-SID values or the range of I-SID values in the layer 2 I-SID list.
