This procedure only applies to the VSP 7400 Series.
Perform this procedure to view remote SPBM nicknames on the switch.
 - Select SPBM Remote.
 - Select the Nick Names tab.
Nick Names Field Descriptions
Use the data in the following table to use the Nick Names tab.
 Name  |
 Description  |
 Level  |
 Indicates the level at which the system displays this LSP.  |
 ID  |
 Indicates the 8 byte LSP ID, consisting of the System ID, Circuit ID, and Fragment Number.  |
 LifetimeRemain  |
 Indicates the remaining lifetime in seconds for the LSP.  |
 NickName  |
 Indicates the nickname for the remote SPBM node.  |
 HostName  |
 Indicates the hostname that the system displays in the LSP, or the system name if the host name is not configured.  |
