Use the following commands to display IGMP information.
  1. Enter Privileged EXEC mode:
    enable
  2. Display information about the interfaces where IGMP is enabled:
    show ip igmp interface [gigabitethernet {slot/port[/sub-port][-slot/port[/sub-port]][,...]}][vlan <1-4059>][vrf WORD<1–16>][vrfids WORD<0–512>]
    Ensure that the ouput displays routed-spb under MODE.
  3. Display information about the IGMP cache:
    show ip igmp cache [vrf WORD<1–16>][vrfids WORD<0–512>]
  4. Display information about the IGMP group:
    show ip igmp group [count][group {A.B.C.D}][member-subnet default|{A.B.C.D/X}][vrf WORD<1–16>][vrfids WORD<0–512>]
  5. Display information about the IGMP sender:
    show ip igmp sender [count][group {A.B.C.D}][member-subnet default|{A.B.C.D/X}][vrf WORD<1–16>][vrfids WORD<0–512>]
Display IGMP information for IP multicast over Fabric Connect within the GRT:
Switch:1#show ip igmp interface
                         Igmp Interface - GlobalRouter
       QUERY              OPER           QUERY   WRONG              LASTMEM                     SCOPE
IF     INTVL STATUS VERS. VERS QUERIER   MAXRSPT QUERY JOINS ROBUST QUERY   MODE       L2ISID   ISID
V100   125    activ  2     2   0.0.0.0    100     0     0     2      10      snoop-spb 1100
1 out of 1 entries displayed
Switch:1#show ip igmp interface vlan 2
                                  Vlan Ip Igmp
VLAN QUERY QUERY ROBUST VERSION LAST  PROXY  SNOOP  SNOOP    SSM    UPnP   FAST   FAST
ID   INTVL MAX                  MEMB  SNOOP  ENABLE ORIGIN   SNOOP  FILTER LEAVE  LEAVE
           RESP                 QUERY ENABLE                 ENABLE ENABLE ENABLE PORTS
2   125   100   2      2       10    false   false   RADIUS   false   false   false
VLAN SNOOP   SNOOP           DYNAMIC   COMPATIBILITY EXPLICIT UPnP
ID   QUERIER QUERIER         DOWNGRADE MODE          HOSTS    FILTER
     ENABLE  ADDRESS         VERSION                 TRACKING ADDRESS
2   false   0.0.0.0         enable    disable       disable  239.255.255.250/32
Switch:1# show ip igmp sender
		 IGMP Sender - GlobalRouter
                              PORT/
GRPADDR   IFINDEX    MEMBER    MLT    STATE      L2ISID SCOPEISID  DATAISID
224.1.1.4  Vlan 10  192.2.0.1  1/18/1  NOTFILTERED   0  10010    16000001
224.1.1.4  Vlan 10  192.2.0.1  1/18/1  NOTFILTERED   0  10010    16000004
224.1.1.6  Vlan 10  192.2.0.1  1/18/1  FILTERED      0  10010    16000010
224.1.1.7  Vlan 10  192.2.0.1  1/18/1  FILTERED      0  10010    16000009
224.1.1.8  Vlan 10  192.2.0.1  1/18/1  NOTFILTERED   0  10010     210
5 out of 5 entries displayed
Switch:1#show ip igmp group
                           Igmp Group - GlobalRouter
GRPADDR         INPORT          MEMBER          EXPIRATION TYPE       L2ISID
224.5.2.1       V701-1/4        62.0.1.1        214        Dynamic    40400
224.5.2.2       V702-1/4        62.0.2.1        221        Dynamic    40400
224.5.2.3       V703-1/4        62.0.3.1        217        Dynamic    40400
224.5.2.4       V704-1/4        62.0.4.1        223        Dynamic    40400
4 out of 4 group Receivers displayed
Total number of unique groups 2
