Configure the DHCP relay behavior on the interface.
You can configure only one relay for a VLAN, regardless of how many addresses are configured on that VLAN. The default address is the smallest address configured. If the relay is a VRRP address, the default value is the first VRRP address configured.
Configure the maximum hop count:
Switch:1(config-if)#ipv6 dhcp-relay max-hop 30
Disable the remote ID:
Switch:1(config-if)#no ipv6 dhcp-relay remote-id
Use the data in the following table to use the ipv6 dhcp-relay command.
                                 Variable  |
                                 Value  |
                                 max-hop <1–32>  |
                                 Specifies the maximum number of hops a DHCP packet can take from the DHCP client to the DHCP server. The default is 32.  |
                                 remote-id  |
                                 Enables the relay agent to add information about the relay to DHCPv6 messages before relaying the messages to the DHCP server. The default is disabled  |
Use the data in the following table to use the interface command.
                                 Variable  |
                                 Value  |
                                 <1-4059>  |
                                 Specifies the VLAN ID in the range of 1 to 4059. By default, VLAN IDs 1 to 4059 are configurable and the system reserves VLAN IDs 4060 to 4094 for internal use. On switches that support the vrf-scaling and spbm-config-mode boot configuration flags, if you enable these flags, the system also reserves VLAN IDs 3500 to 3998. VLAN ID 1 is the default VLAN and you cannot create or delete VLAN ID 1.  |
                                 {slot/port[/sub-port][-slot/port[/sub-port]][,...]}  |
                                 Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
