Use ACE Ethernet VLAN ID entries so that the filter looks for traffic on specific VLANs. You can insert an ACE Ethernet VLAN ID only for ACL VLAN types.
The ACL exists.
The ACE exists.
 - Click Advanced Filters (ACE/ACLs).
 - Click the ACL tab.
 - Select the appropriate ACL.
 - Click ACE.
 - Select the appropriate ACE.
 - Click Eth.
 - Click the Vlan Id tab.
 - Click Insert.
 - Specify the operation type.
 - Enter the VLAN ID or select from a list.
 - Click Insert.
VLAN ID field descriptions
Use the data in the following table to use the Vlan Id tab.
 Name  |
 Description  |
 AclId  |
 Specifies the ACL ID.  |
 AceId  |
 Specifies the ACE ID.  |
 Oper  |
 The eq parameter specifies an operator for a field match condition: equal to.  |
 VlanId  |
 Specifies the VLAN ID on which to perform a match.  |
 OperMask  |
 Specifies the mask value for a VLAN attribute.  |
