Use the following procedure to configure SPBM on an interface.
 - Select IS-IS.
 - Select the Interfaces tab.
 - Select the SPBM button.
 - In the Interfaces SPBM tab, select Insert.
 - Select Insert.
SPBM field descriptions
Use the data in the following table to use the Interfaces SPBM tab.
                         Name  |
                         Description  |
                         Index  |
                         Specifies an Index value for the SPBM interface.  |
                         SpbmId  |
                         Specifies the SPBM ID.  |
                         State  |
                         Specifies whether the SPBM interface is enabled or disabled.  |
                         Type  |
                         Configures the SPBM instance interface-type on the IS-IS interface located on the specified port or MLT: ptpt or bcast. Only the point-to-point (ptpt) interface type is supported.  |
                         L1Metric  |
                         Configures the IS-IS Interface level 1 metric on the specified port or MLT. The default value is 10.  |
| Origin Note:
Exception: not supported on VSP 8600 Series or XA1400 Series.  |
                                 Specifies the source of the SPBM instance configuration, either manually configured through CLI or EDM, or dynamically configured through Auto-sense.  |
