This procedure only applies to VSP 8600 Series.
Use this task to view IPv6 operational routes.
 - Select Mgmt Instance.
 - Select the MgmtIpv6Route tab.
MgmtIpv6Route Field Descriptions
Use the data in the following table to use the MgmtIpv6Route tab.
 Name  |
 Description  |
 DestAddr  |
 Shows the destination address of the route entry.  |
 PrefixLen  |
 Shows the destination prefix length of the route entry.  |
 Metric  |
 Shows the metric, or cost, assigned to the route entry. If multiple entries exist to the same destination, the metric determines which route is used. Routes with a type of LOCAL have a metric equal to 256.  |
 Instance  |
 Shows the Management Instance ID.  |
 NextHop  |
 Shows the next hop for the route entry.  |
 IntfName  |
 Shows the Management Instance interface name for the route entry.  |
 Type  |
 Shows the type of route entry.  |
