Use the following procedure to clear all IPv4 Multicast Source Discovery Protocol (MSDP) statistics for all peers or a specific peer.
The switch supports this command for local management VRF or global routing table (GRT). If you do not specify a VRF or VRF ID, the switch defaults to GRT.
Use the data in the following table to use the clear ip msdp statistics command.
 Variable  |
 Value  |
 vrf WORD<0–16>  |
 Specifies a VRF instance by VRF name.  |
 vrfids WORD<0–512>  |
 Specifies the ID of the VRF.  |
 {A.B.C.D.}  |
 Specifies the IPv4 MSDP address for a specific peer.  |
