Configure IGMP sender entries to identify a source that sends multicast data to a multicast group.
You can configure IGMP on a VRF instance the same way you configure the Global Router except that you must first launch the appropriate VRF context.
  1. In the navigation pane, expand the following folders: Configuration > IP.
  2. Select IGMP.
  3. Select the Sender tab.
  4. Change the appropriate options.
  5. Select Apply.
Sender field descriptions
Use the data in the following table to use the Sender tab.
Name
Description
IfIndex
Specifies the interface where you enabled the IGMP entry.
GrpAddr
Specifies the multicast group address of the multicast stream.
Within the indicated valid range (224.0.0.0 to 239.255.255.255), the following are invalid addresses: 244.0.0.x and the corresponding 31 multicast addresses that map to the IP MAC addresses. If you try to select them, you receive an error message.
MemberAddr
Specifies the IP address of a host.
Action
Flushes an entry or a group.
TPort
Identifies the T port.
State
Indicates whether a sender exists because of an IGMP access filter. The options are filtered and not filtered.
L2Isid
Specifies the Layer 2 I-SID of the C-VLAN.
ScopeIsid
Indicates the scope I-SID of SPB routed multicast sender. If the sender does not support an SPB scope I-SID, the field displays an invalid value of 0xFFFFFFFF.
DataIsid
Indicates the data I-SID of SPB routed multicast sender. If the sender does not support an SPB data I-SID, the field displays an invalid value of 0xFFFFFFFF.
