After the platform boot sequence is complete, the system opens the logon prompt. The following table shows the default values for logon and password for console and Telnet sessions.
With enhanced secure mode enabled, the person in the role-based authentication level of administrator configures the login and password values for the other role-based authentication levels. The administrator initially logs on to the switch using the default login of admin and the default password of admin. After the initial login, the switch prompts the administrator to create a new password.
 Access level  |
 Description  |
 Default logon  |
 Default password  |
 Read-only  |
 Permits view-only configuration and status information. Is equivalent to Simple Network Management Protocol (SNMP) read-only community access.  |
 ro  |
 ro  |
 Layer 1 read/write  |
 View most switch configuration and status information and change physical port settings.  |
 l1  |
 l1  |
 Layer 2 read/write  |
 View and change configuration and status information for Layer 2 (bridging and switching) functions.  |
 l2  |
 l2  |
 Layer 3 read/write  |
 View and change configuration and status information for Layer 2 and Layer 3 (routing) functions.  |
 l3  |
 l3  |
 Read/write  |
 View and change configuration and status information across the switch. You cannot change security and password settings. This access level is equivalent to SNMP read/write community access.  |
 rw  |
 rw  |
 Read/write/all  |
 Permits all the rights of read/write access and the ability to change security settings, including CLI and web-based management user names and passwords and the SNMP community strings.  |
 rwa  |
 rwa  |
