Display information about BGPv6 routes.
The following table defines parameters for the show bgp ipv6 route command.
 Variable  |
 Value  |
 [<WORD 1-256>]  |
 Specifies the IPv6 prefix and the prefix length (must be an integer value between 0 and 128).  |
 community <enable|disable>  |
 Enables or disables the display of community attributes.  |
 ipv6 <WORD 1-256>]  |
 Specifies an IPv6 address.  |
 longer-prefixes  |
 Shows long prefixes. The longer-prefixes indicate the mask length from any specified prefix to 128 (for example, show from prefix X:X::X:X/len to X:X::X:X/ 128).  |
                             vrf  |
                             Specifies a VRF instance by name (the string length ranges from 1–16 characters).  |
                             vrfids  |
                             Specifies a range of VRFs by ID number (the ID ranges from 0–255).  |
