View Layer 2 IP Ping Results
Use this procedure to view Layer 2 IP ping results.
After you trigger Layer 2 IP Ping, you must click the Refresh button to update the results.
 - Click L2Ping/L2Trace Route.
 - Click the L2 IP Ping tab.
 - To view the Layer 2 IP ping results, highlight an entry, and then click Result.
L2 IP Ping Result Field Descriptions
Use the data in the following table to use the L2 IP Ping Result tab.
 Name  |
 Description  |
 IpAddrType  |
 The address type of the destination IP Address.  |
 IpAddr  |
 Destination IP Address.  |
 SendOrder  |
 Specifies the order that sessions were sent. It is an index to distinguish among multiple L2Ping sessions. This value is assigned sequentially from 1. It correlates to the number of paths found.  |
 VrfId  |
 Specifies the VRF ID.  |
 VlanId  |
 Specifies the VLAN ID found from the Layer 3 lookup and used for transmission.  |
 DestMacAddress  |
 An indication of the target MAC Address transmitted.  |
 PortNum  |
 Either the value '0', or the port number of the port used for the l2 IP ping.  |
 DestHostName  |
 The host name of the responding node.  |
 Size  |
 The number of bytes of data sent.  |
 PktsTx  |
 Number of Packets transmitted for this VLAN/MAC.  |
 PktsRx  |
 Number of Packets received for this VLAN/MAC.  |
 PercentLossWhole  |
 Percentage of packet loss for this VLAN/MAC.  |
 PercentLossFract  |
 MinRoundTrip  |
 Minimum time for round-trip for this VLAN/MAC in us.  |
 MaxRoundTrip  |
 Maximum time for round-trip for this VLAN/MAC in us.  |
 RttAvgWhole  |
 Average time for round-trip for this VLAN/MAC in us.  |
 RttAvgFract  |
 Fractional portion of average time for round-trip.  |
 Flag  |
 Result flag indicating status or error code:
