This procedure only applies to VSP 4450 Series.
View port bridging errors statistics to manage network performance.
- In the Device Physical View, select a port.
 - In the navigation pane, expand: .
 - Select Port.
 - Select the Bridging tab.
Bridging Field Descriptions
The following table describes parameters on the Bridging tab.
 Name  |
 Description  |
 InUnicastFrames  |
 The number of incoming unicast frames bridged.  |
 InMulticastFrames  |
 The number of incoming multicast frames bridged.  |
 InBroadcastFrames  |
 The number of incoming broadcast frames bridged.  |
 InDiscards  |
 The number of frames discarded by the bridging entity.  |
 OutFrames  |
 The number of outgoing frames bridged.  |
