Use this procedure to display information about the groups configured in this device.
- In the navigation pane, expand the following folders: .
 - Click IPv6 MLD.
 - Click the Group tab.
Group field description
Use the data in the following table to use the Group tab.
 Field  |
 Description  |
 IPv6Address  |
 Specifies the multicast group address that others want to join to. A group address can be the same for many incoming ports.  |
 Members  |
 Specifies the IP address of a source that has sent group report whishing to join this group.  |
 InPort  |
 Identifies a physical interface or a logical interface which has received group reports from various sources.  |
 Expiration  |
 Specifies the time left before group report expires on this port. This is updated upon receiving a group report.  |
 IfIndex  |
