Use the following procedure to configure OVSDB managed interfaces on the switch.
You must enable VXLAN Gateway Full Interworking Mode. For more information, see Enable VXLAN Gateway in Full Interworking Mode.
You must create the required Flex UNI or CVLAN I-SIDs before you configure the OVSDB managed interface.
SWITCH:1>enable SWITCH:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. SWITCH:1(config)#ovsdb SWITCH:1(config-ovsdb)#managed-interface i-sids 300 SWITCH:1(config-ovsdb)#managed-interface i-sids 500
What to do next
Configure the OVSDB protocol support for VXLAN Gateway, see Configuring OVSDB protocol support for VXLAN Gateway.
Variable definitions
Use the data in the following table to use the managed-interface command.
 Variable  |
 Value  |
 i-sids WORD<1–1024>  |
 Specifies the I-SID information to create an interface to manage OVSDB protocol support for VXLAN Gateway. Note:
You must create the required Flex UNI or CVLAN I-SIDs before you configure the managed interface I-SID.  |
